Camshaft TU24
Arno Bergsma
Camshaft TU24
Message par Arno Bergsma »
Hai,
I´ve been searching for specification of a originele camschaft of a TU24.... (spécification á l'origine arbre à cames) :blush:
I don´t known if it is 256 degrees or 270 degrees!?
Can somebody help me with this??
I can´t found it in FAQ.....(je n'ai pas pu le trouver dans FAQ)
In The Netherlands i can´t find anything abuot this :(
Sorry again....me French is crappy.....so i wrote it down in English... :blush:
Remercie déjà
Arno
Peugeot 205 1.3 Rallye 1988 TU24
Peugeot 106 1.3 Rallye 1995 TU2J2
Peugeot 307 2.0 16V SW 2005 EW10A
Been thanked : 41 times
Re: Camshaft TU24
i can give you the camshaft spécification but with 1mm on cams, it's the manufacturer's data....
have you a problem with your rallye?
Arno Bergsma
Re: Camshaft TU24
Hai CriCri,
I´ve got 2 broken valvesprings and my camshaft is a bit damaged.... :crying:
So i am looking for the originele specs of the camschaft because I want assemble faster one.
I want to buy a 279 degrees camshaft from CatCams.
But i don´t know the originele specs..... :blush:
Do you have the manufacture´s specs??
Re: Camshaft TU24
ok, you can buy a camshaft on our forum, you must post on "annonces pieces d'origine", it cost approximative 50€....
for valve spring, buy new on Peugeot parts, ref 0952 62, 10,82€ TTC...
i will scan the camshaft specifications, give me your mail by mp... ;)
Arno Bergsma
Re: Camshaft TU24
You´ve got mail.... :ok:
Re: Camshaft TU24
ok i will send you that in the evening.... ;)
Arno Bergsma
Re: Camshaft TU24
Oke thanks.....j'ai été intrigué.... ;)
