Bearing diameter
Bearing diameter
Message par Bearing diameter »
Hello all! I am looking for an camshaft from CAT CAMS for my Ax sport but there are two sizes of camshaft bearing diameters.
42,42 - 41,82 - 41,23 - 40,62 - 36,92
and
44,12 - 43,62 - 43,12 - 42,62 - 36,92
Can someone tell me wich one ir right for TU24 and what are "roller rockers"?
Thanks very much
Andrej
Some peoples says first AX Sport (1987 models) got smallest camshaft bearing. I don't think so.
Maybe you can ask the camshat seller? CatCams give the same ref for TU2/4 and TU3 .. I think the difference is between the.. or maybe other motors
Do you know this site: <a href='http://www.catcams.be/index.htm' target='_blank'>http://www.catcams.be/index.htm</a> ?
if you take a look at camshaft for TU3/5 (SMALL BEARING RANGE) you only see "42,42 - 41,82 - 41,23 - 40,62 - 36,92" bearing, and information for TU24
and for TU3M (BIG BEARING RANGE) bearing are "4,12 - 43,62 - 43,12 - 42,62 - 36,92"
Ask them to be sure, but I'm 99.9% sure that all 205 Rallye and all AX Sport got small camshaft bearing ;)
Modifié en dernier par Oliive le 10 mai 2005, 15:00, modifié 1 fois.
Guest
Message par Guest »
Oliive a écrit :Do you know this site: <a href='http://www.catcams.be/index.htm' target='_blank'>http://www.catcams.be/index.htm</a> ?
Yes, i looked at that site but there is only 106 rallye and i wasnt sure if it is the same head as in AX. I asked a few more people here and they told me 99% small bearing.
Thanks!
BTW If anyone has some expirience with these camshafts is free to speak :D
