Pictures of Danish Rallye
- Rallye Danemark
- Débutant
- megastef
- Amateur
Hi, Rallye Danemark.
Your 205 is very nice
In my opinion, the 106 rallye wheels are the best fit for our car: better size, same "spirit" !
Your car is very clean. Is the painting stock, or did you have it repainted ? (looks very shiny)
And, what about the black rubber things on the front bumper ?
The rear windscreen wiper, did you set it yourself ? (The french Rallye went without it...) Is it difficult to set ?
Nice car, really ;-)
- Rallye Danemark
- Débutant
Well...Its the original paintwork. I just T-cut it (colour restorer) and waxed it this morning..Makes a big difference. It was totally dull before..Still Some rust on the doors and boot..might get them resprayed at some point...Your car is very clean. Is the painting stock, or did you have it repainted ? (looks very shiny)
They are headlamp washers. Each one has two washer jets that clean the headlamps when the lights are on and you use the windsceen washers..(I think never seen them working). There is a tank for the washer fluid behind the passenger side headlamp.And, what about the black rubber things on the front bumper ?
The rear windscreen wiper came with the car. I think they must have been standard in denmark. To fit one yourself it can't be so hard you would maybe need...The rear windscreen wiper, did you set it yourself ? (The french Rallye went without it...) Is it difficult to set ?
A tank for the fluid at the back with washer motor
A washer nozzle
Wiper arm & blade
wiper motor
wiper relay
new wiper switch
plastic tubing
Must be loads of 205's in scrap yards you can get this stuff from
- sebvolstroff
- Amateur
