Fuel pump / pipes
thiscocks1
A remercié : 21 fois
A été remercié : 8 fois
Fuel pump / pipes
Message par thiscocks1 »
Hi,
I am trying to start up my new engine in my AX sport. It cranks over fine but doesn't seem to be pumping fuel from the tank. Which fuel pipes going into the engine bay are return and send? I forgot to mark each one when I removed them :(
Is there a possibility the fuel pump lever can be mounted incorrectly?
couple of pics of my engine when I fitted it:
Regards,
Tim
A remercié : 287 fois
A été remercié : 301 fois
Re: Fuel pump / pipes
I never disassembled fuel pump, I don't know how it is actuated by the shaft of the engine.
Maybe it is just actuated by contact on the cam.
A friend recently has had a problem with his pump
Did you check it ?
